Probabilistic Fault Diagnosis in the MAGNETO Autonomic Control Loop - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Management of outer edge domains is a big challenge for service providers due to the diversity, heterogeneity and large amount of such networks, together with limited visibility on their status. This paper focuses on the probabilistic fault diagnosis functionality developed in the MAGNETO project, which enables finding the most probable cause of service problems and thus triggering appropriate repair actions. Moreover, its self-learning capabilities allow continuously enhancing the accuracy of the diagnostic process.
61550103.pdf (507.85 Ko) Télécharger le fichier
hal-01056642 , version 1 (20-08-2014)
Paternité
Pablo Arozarena, Raquel Toribio, Jesse Kielthy, Kevin Quinn, Martin Zach. Probabilistic Fault Diagnosis in the MAGNETO Autonomic Control Loop. 4th International Conference on Autonomous Infrastructure, Management and Security (AIMS), Jun 2010, Zurich, Switzerland. pp.102-105, ⟨10.1007/978-3-642-13986-4_14⟩. ⟨hal-01056642⟩
104 Consultations
133 Téléchargements
