PriMan : A Privacy-Preserving Identity Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
PriMan is presented; privacy-preserving user-centric identity management middleware which defines and groups the required functionality. It offers the application developer a uniform technology-agnostic interface to use and combine different types of privacy enhancing technologies. Moreover, the PriMan framework defines all the components and their functionality required to raise the development of privacy enhanced client-server applications to a higher level.
_41.pdf (432.38 Ko) Télécharger le fichier
hal-01056676 , version 1 (20-08-2014)
Paternité
Kristof Verslype, Pieter Verhaeghe, Jorn Lapon, Vincent Naessens, Bart Decker. PriMan : A Privacy-Preserving Identity Framework. 24th Annual IFIP WG 11.3 Working Conference on Data and Applications Security and Privacy (DBSEC), Jun 2010, Rome, Italy. pp.327-334, ⟨10.1007/978-3-642-13739-6_24⟩. ⟨hal-01056676⟩
136 Consultations
91 Téléchargements
