A compact chipless RFID tag with environment sensing capability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a chipless RFID tag having both identification and sensing capability. It is based on 5 resonant scatterers that behave as signal processing antennas in the band from 2.5 to 7.5 GHz. Only one scatterer is used to monitor a physical parameter variation, while the four others allow identifying the remote sensor with 13 bits. To make a resonator sensitive to the temperature or humidity, a material based on Silicon Nanowire is deposited on the tag surface using a very simple process. The tag needs only one conductive layer so that it can be directly printed on product making by the way a unit cost potentially very low. Measurements done using a bi static radar configuration in the frequency domain validate this new concept.
Fichier non déposé
hal-01056740 , version 1 (20-08-2014)
Arnaud Vena, Etienne Perret, Smail Tedjini, Darine Kaddour, Alexis Potie, et al.. A compact chipless RFID tag with environment sensing capability. Microwave Symposium Digest (MTT), 2012 IEEE MTT-S International, Jun 2012, Unknown, France. pp.1-3, ⟨10.1109/mwsym.2012.6258420⟩. ⟨hal-01056740⟩
109 Consultations
0 Téléchargements
