Conference papers
New RF identification technology for secure applications
Abstract : The paper presents the design and development of a low cost chipless RFID system for secure near field data transfer. This system is ideal for use in credit cards and similar identification cards which are based on "data transfer by contact" which at present uses the conventional using integrated circuits (IC) or magnetic strips. The system consists of the design of a compatible low cost tag as well as the measurement set up using a metallic cavity. Using the presented technique it is easily possible to code 23 bits within the dimensions of a conventional credit card. Emphasis is given to security as well as larger data capability. It can be seen that the presented technique is robust and cost effective compared to the existing techniques and can be used as a viable alternative in identification cards based on data transfer by contact.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01056845
Contributor : Valence Lcis Connect in order to contact the contributor
Submitted on : Wednesday, August 20, 2014 - 3:46:01 PM
Last modification on : Friday, November 6, 2020 - 4:37:52 AM
Identifiers
Collections
Citation
V. Deepu, Arnaud Vena, Etienne Perret, Smail Tedjini. New RF identification technology for secure applications. RFID-Technology and Applications (RFID-TA), 2010 IEEE International Conference on, Jun 2010, Unknown, pp.159-163, ⟨10.1109/rfid-ta.2010.5529879⟩. ⟨hal-01056845⟩
Share
Metrics
Record views
43
