Abstract : Wireless communication systems had an enormous growth in the last decade: GSM, WiFi, RFID, blue-tooth... They are now present everywhere in our environment with the electromagnetic waves (EMW) that go with them. Curiously, however, there is not so many techniques to block or to attenuate those EMW that are well adapted to protect rooms, apartments or industrial buildings. In that context, we developed and proposed a wallpaper that selectively blocks EMW. It is made of a paper substrate on which a conductive frequency selective surface (SSF) is printed with conductive ink. A new design of SSF was specially developed for that application. It can filter two or three different frequencies, it is insensitive to the polarization of the electric field and also to the angle of incidence of the EMW. WiFI signals or GSM one can be filtered while other frequencies (for radio or TV or emergency communication) have little attenuation (<5dB). Different printing technologies were studied and tested. The effect of the electromagnetic properties of the paper were also studied. Some samples were realized by flexography techniques with an industrial equipment and with serigraphy. Results are slightly better with serigraphy and agree well with the simulations. Attenuation of 28 dB and 20 dB were obtained at 2.45 and 5.5 GHz respectively.
