Design of Antennas for UHF RFID Tags - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the IEEE Année : 2012
This paper is mainly dedicated to the design of radio-frequency identification (RFID) tags, particularly the antennas that allow the tag to be fed, communicate, and exchange data with the reader. Good performance tags require optimized antenna that take into account numerous constraints as well as the environment of the application under consideration. Both conventional tags and robust tags are discussed. This paper also discusses how to transform a tag into an RFID sensor.
Fichier non déposé
hal-01056892 , version 1 (20-08-2014)
Etienne Perret, Smail Tedjini, Raji Sasidharan Nair. Design of Antennas for UHF RFID Tags. Proceedings of the IEEE, 2012, 100 (7), pp.2330-2340. ⟨10.1109/jproc.2012.2186950⟩. ⟨hal-01056892⟩
Collections
UGA LCIS
248 Consultations
0 Téléchargements
