Interpretation, Evaluation and the Semantic Gap ... What if we Were on a Side-Track? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A significant amount of research in Document Image Analysis, and Machine Perception in general, relies on the extraction and analysis of signal cues with the goal of interpreting them into higher level information. This paper gives an overview on how this interpretation process is usually considered, and how the research communities proceed in evaluating existing approaches and methods developed for realizing these processes. Evaluation being an essential part to measuring the quality of research and assessing the progress of the state-of-the art, our work aims at showing that classical evaluation methods are not necessarily well suited for interpretation problems, or, at least, that they introduce a strong bias, not necessarily visible at first sight, and that new ways of comparing methods and measuring performance are necessary. It also shows that the infamous {\em Semantic Gap} seems to be an inherent and unavoidable part of the general interpretation process, especially when considered within the framework of traditional evaluation. The use of Formal Concept Analysis is put forward to leverage these limitations into a new tool to the analysis and comparison of interpretation contexts.
GREC_2013_LNCS.pdf (742.19 Ko) Télécharger le fichier
hal-01057362 , version 1 (22-08-2014)
  • HAL Id : hal-01057362 , version 1
Bart Lamiroy. Interpretation, Evaluation and the Semantic Gap ... What if we Were on a Side-Track?. 10th IAPR International Workshop on Graphics Recognition, GREC 2013, Aug 2013, Bethlehem, PA, United States. pp.213-226. ⟨hal-01057362⟩
160 Consultations
148 Téléchargements
