Task-based programming for Seismic Imaging: Preliminary Results
The level of hardware complexity of current super- computers is forcing the High Performance Computing (HPC) community to reconsider parallel programming paradigms and standards. The high-level of hardware abstraction provided by task-based paradigms make them excellent candidates for writing portable codes that can consistently deliver high performance across a wide range of platforms. While this paradigm has proved efficient for achieving such goals for dense and sparse linear solvers, it is yet to be demonstrated that industrial parallel codes--relying on the classical Message Passing Interface (MPI) standard and that accumulate dozens of years of expertise (and countless lines of code)--may be revisited to turn them into efficient task-based programs. In this paper, we study the applica- bility of task-based programming in the case of a Reverse Time Migration (RTM) application for Seismic Imaging. The initial MPI-based application is turned into a task-based code executed on top of the PaRSEC runtime system. Preliminary results show that the approach is competitive with (and even potentially superior to) the original MPI code on a homogeneous multicore node, and can more efficiently exploit complex hardware such as a cache coherent Non Uniform Memory Access (ccNUMA) node or an Intel Xeon Phi accelerator.
