A generalized permutation approach to job shop scheduling with genetic algorithms, OR Spektrum, vol.38, issue.2-3, pp.87-92, 1995. ,
DOI : 10.1007/BF01719250
Production Scheduling and Rescheduling with Genetic Algorithms, Evolutionary Computation, vol.38, issue.1, pp.1-17, 1999. ,
DOI : 10.1016/0278-6125(91)90037-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.266
A review of some methods for ranking fuzzy subsets, Fuzzy Sets and Systems, vol.15, issue.1, pp.1-19, 1985. ,
DOI : 10.1016/0165-0114(85)90012-0
A tutorial survey of job-shop scheduling problems using genetic algorithms???I. representation, Computers & Industrial Engineering, vol.30, issue.4, pp.983-997, 1996. ,
DOI : 10.1016/0360-8352(96)00047-2
A Fast Elitist Non-dominated Sorting Genetic Algorithm for Multi-objective Optimization: NSGA-II, Parallel Problem Solving from Nature PPSN VI, pp.849-858, 2000. ,
DOI : 10.1007/3-540-45356-3_83
A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
DOI : 10.1109/4235.996017
Jobshop scheduling with imprecise durations: a fuzzy approach, IEEE Transactions on Fuzzy Systems, vol.5, issue.4, pp.557-569, 1997. ,
DOI : 10.1109/91.649907
Ranking and defuzzification methods based on area compensation, Fuzzy Sets and Systems, vol.82, issue.3, pp.319-330, 1996. ,
DOI : 10.1016/0165-0114(95)00273-1
Algorithms for Solving Production-Scheduling Problems, Operations Research, vol.8, issue.4, pp.487-503, 1960. ,
DOI : 10.1287/opre.8.4.487
Semantics of Schedules for the Fuzzy Job-Shop Problem, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.38, issue.3, pp.655-666, 2008. ,
DOI : 10.1109/TSMCA.2008.918603
A Memetic Approach to Fuzzy Job Shop Based on Expectation Model, 2007 IEEE International Fuzzy Systems Conference, pp.1-6, 2007. ,
DOI : 10.1109/FUZZY.2007.4295450
Scheduling with Memetic Algorithms over the Spaces of Semi-active and Active Schedules, Lecture Notes in Computer Science, vol.4029, pp.370-379, 2006. ,
DOI : 10.1007/11785231_40
A genetic solution based on lexicographical goal programming for a multiobjective job shop with uncertainty, Journal of Intelligent Manufacturing, vol.24, issue.3, pp.65-73, 2010. ,
DOI : 10.1007/s10845-008-0161-x
Improved local search for job shop scheduling with uncertain durations, Nineteenth Int. Conf. on Automated Planning and Scheduling (ICAPS-2009, pp.154-161, 2009. ,
A hybrid genetic algorithm for the job shop scheduling problem, European Journal of Operational Research, vol.167, issue.1, pp.77-95, 2005. ,
DOI : 10.1016/j.ejor.2004.03.012
Deterministic job-shop scheduling: Past, present and future, European Journal of Operational Research, vol.113, issue.2, pp.390-434, 1999. ,
DOI : 10.1016/S0377-2217(98)00113-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.54.9979
Improving robustness and flexibility of tardiness and total flow-time job shops using robustness measures, Applied Soft Computing, vol.1, issue.1, pp.35-52, 2001. ,
DOI : 10.1016/S1568-4946(01)00005-9
Supplement to Resource constrained project scheduling: An experimental investigation of heuristic scheduling techniques, 1984. ,
Using fuzzy numbers in knapsack problems, European Journal of Operational Research, vol.135, issue.1, pp.158-176, 2001. ,
DOI : 10.1016/S0377-2217(00)00310-6
Expected value of fuzzy variable and fuzzy expected value models, IEEE Transactions on Fuzzy Systems, vol.10, issue.4, pp.445-450, 2002. ,
Conventional genetic algorithm for job shop problems, Proceedings of ICGA, pp.474-479, 1991. ,
A hybrid genetic algorithm for the job shop scheduling problems, Computers & Industrial Engineering, vol.45, issue.4, pp.597-613, 2003. ,
DOI : 10.1016/S0360-8352(03)00077-9
Scheduling: Theory, Algorithms, and Systems, 2008. ,
Fast local search for fuzzy job shop scheduling, Proceedings of ECAI 2010, pp.739-744, 2010. ,
Muiltiobjective Optimization Using Nondominated Sorting in Genetic Algorithms, Evolutionary Computation, vol.27, issue.3, pp.221-248, 1994. ,
DOI : 10.1162/evco.1994.2.3.221
New codification schemas for scheduling with genetic algorithms Artificial Intelligence and Knowledge Engineering Applications: A Bioinspired Approach, Lecture Notes in Computer Science, vol.3562, pp.15-20, 2005. ,
A Comparison of Genetic Algorithms for the Static Job Shop Scheduling Problem, Parallel Problem Solving from Nature PPSN VI, pp.303-312, 2000. ,
DOI : 10.1007/3-540-45356-3_30
A procedure for ordering fuzzy subsets of the unit interval, Information Sciences, vol.24, issue.2, pp.143-161, 1981. ,
DOI : 10.1016/0020-0255(81)90017-7
