Conference papers
Simply RIOT: Teaching and Experimental Research in the Internet of Things
Abstract : Manufacturers announce on a regular basis the availability of novel tiny devices, most of them featuring network interfaces: the Internet of Things (IoT) is already here - from the hardware perspective. On the software side however, embedded platforms available so far made it uneasy for developers to build apps that run across heterogeneous IoT hardware. Linux does not scale down to small, energy-constrained devices, while alternatives such as Contiki yield a steep learning curve and lengthy development life-cycles because they rule out standard programming and debugging tools. RIOT is a new open source software platform bridging this gap. RIOT allows just about any programmer to develop IoT application with zero learning curve. This is achieved by allowing standard C and C++ application programming with multi-threading, using well-known debugging tools (gdb, Valgrind, profilers etc.), while requiring only a minimum of 1.5 kB of RAM. RIOT also provides built-in energy efficiency and real-time capabilities. These characteristics make this platform attractive in several contexts, including teaching in the field of the Internet of Things, and experimental research in the domain of sensor networks and the IoT.
Document type :
Conference papers
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/hal-01058634
Contributor : Emmanuel Baccelli Connect in order to contact the contributor
Submitted on : Wednesday, August 27, 2014 - 2:51:20 PM
Last modification on : Thursday, January 20, 2022 - 4:20:50 PM
Long-term archiving on: : Friday, November 28, 2014 - 10:35:59 AM
File
main.pdf
Identifiers
  • HAL Id : hal-01058634, version 1
Collections
Citation
Oliver Hahm, Emmanuel Baccelli, Hauke Petersen, Matthias Wählisch, Thomas Schmidt. Simply RIOT: Teaching and Experimental Research in the Internet of Things. 13th ACM/IEEE International Conference on Information Processing in Sensor Networks (IPSN 2014), Apr 2014, Berlin, Germany. ⟨hal-01058634⟩
Share
Metrics
Record views
269
Files downloads
674
