Abstract : Safety applications designed for Vehicular Ad Hoc Networks (VANETs) can be compromised by participating vehicles transmitting false or inaccurate information. Design of mechanisms that detect such misbehaving nodes is an important problem in VANETs. In this pa- per, we investigate the use of correlated information, called \secondary alerts", generated in response to another alert, called as the \primary alert" to verify the truth or falsity of the primary alert received by a vehi- cle.We ¯rst propose a framework to model how such correlated secondary information observed from more than one source can be integrated to generate a \degree of belief" for the primary alert. We then show an instantiation of the model proposed for the speci¯c case of Post-Crash Noti¯cation as the primary alert and Slow/Stopped Vehicle Advisory as the secondary alerts. Finally, we present the design and evaluation of a misbehavior detection scheme (MDS) for PCN application using such correlated information to illustrate that such information can be used e±ciently for MDS design.
https://hal.inria.fr/hal-01059125 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, August 29, 2014 - 1:48:21 PM Last modification on : Saturday, July 21, 2018 - 4:58:02 PM Long-term archiving on: : Sunday, November 30, 2014 - 10:40:34 AM
Ashish Vulimiri, Arobinda Gupta, Pramit Roy, Skanda N. Muthaiah, Arzad A. Kherani. Application of Secondary Information for Misbehavior Detection in VANETs. 9th International IFIP TC 6 Networking Conference (NETWORKING), May 2010, Chennai, India. pp.385-396, ⟨10.1007/978-3-642-12963-6_31⟩. ⟨hal-01059125⟩
