Approximating and intersecting surfaces from points, Proceedings of the 2003 Eurographics/ACM SIGGRAPH Symposium on Geometry Processing, pp.230-239, 2003. ,
On normals and projection operators for surfaces defined by point sets, Eurographics Symp. on Point-Based Graphics, pp.149-155, 2004. ,
K-means++: The advantages of careful seeding, Proceedings of the Eighteenth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.1027-1035, 2007. ,
On linear variational surface deformation methods. Visualization and Computer Graphics, IEEE Transactions on, vol.14, issue.1, 2008. ,
Topological persistence and simplification, Proceedings of the 41st Annual Symposium on Foundations of Computer Science, vol.2, p.4, 2000. ,
Algebraic point set surfaces, ACM Trans. Graph, vol.26, issue.2, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00354998
Dynamic sampling and rendering of algebraic point set surfaces, Comput. Graph. Forum, vol.27, issue.3, pp.653-662, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00354995
Multiresolution signal processing for meshes, Proceedings of the 26th Annual Conference on Computer Graphics and Interactive Techniques, pp.325-334, 1999. ,
Bounded biharmonic weights for real-time deformation, ACM Trans. Graph, vol.30, issue.4, pp.1-78, 2011. ,
Interactive multi-resolution modeling on arbitrary meshes, Proceedings of the 25th Annual Conference on Computer Graphics and Interactive Techniques, pp.105-114, 1998. ,
Laplace-beltrami eigenfunctions: Towards an algorithm that understands geometry, IEEE International Conference on Shape Modeling and Applications, 2006. ,
Green coordinates, ACM Trans. Graph, vol.27, issue.10, pp.1-78, 2008. ,
Point-based manifold harmonics, IEEE Transactions on Visualization and Computer Graphics, vol.18, issue.2, pp.1693-1703, 2012. ,
Growing least squares for the analysis of manifolds in scale-space, vol.31, p.4 ,
Compressed manifold modes for mesh processing ,
Selection of k in k-means clustering, Proceedings of the Institution of Mechanical Engineers, Part C: Journal of Mechanical Engineering Science, vol.219, issue.6, pp.103-119, 2005. ,
Multi-scale feature extraction on point-sampled surfaces, Computer Graphics Forum, vol.22, issue.4, pp.281-289, 2003. ,
Point-based multiscale surface representation, ACM Trans. Graph, vol.25, p.7, 2006. ,
Shape modeling with point-sampled geometry, ACM Trans. Graph, vol.22, issue.3, pp.641-650, 2003. ,
Surface-and volumebased techniques for shape modeling and analysis, SIG-GRAPH Asia, pp.1-65, 2013. ,
Heat diffusion kernel and distance on surface meshes and point sets, Computers & Graphics, vol.37, issue.2, pp.676-686, 2013. ,
A scale space based persistence measure for critical points in 2d scalar fields. Visualization and Computer Graphics, IEEE Transactions on, vol.17, issue.4, pp.2045-2052, 2011. ,
A concise and provably informative multi-scale signature based on heat diffusion, Proceedings of the Symposium on Geometry Processing, pp.1383-1392, 2009. ,
, Spectral geometry processing with manifold harmonics. Computer Graphics Forum (Proceedings Eurographics, 2008.
Progressive compression of point-sampled models, Proceedings of the First Eurographics Conference on Point-Based Graphics, pp.95-103, 2004. ,
Pointshop 3d: An interactive system for point-based surface editing, ACM Trans. Graph, vol.21, issue.3, pp.322-329, 2002. ,
, Spectral mesh processing, vol.29, pp.1865-1894, 2010.
