A Case Study: Privacy Preserving Release of Spatio-temporal Density in Paris - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With billions of handsets in use worldwide, the quantity of mobility data is gigantic. When aggregated they can help understand complex processes, such as the spread viruses, and built better transportation systems, prevent traffic con- gestion. While the benefits provided by these datasets are indisputable, they unfortunately pose a considerable threat to location privacy. In this paper, we present a new anonymization scheme to release the spatio-temporal density of Paris, in France, i.e., the number of individuals in 989 different areas of the city released every hour over a whole week. The density is computed from a call-data-record (CDR) dataset, pro- vided by the French Telecom operator Orange, containing the CDR of roughly 2 million users over one week. Our scheme is differential private, and hence, provides provable privacy guarantee to each individual in the dataset. Our main goal with this case study is to show that, even with large dimensional sensitive data, differential privacy can pro- vide practical utility with meaningful privacy guarantee, if the anonymization scheme is carefully designed. This work is part of the national project XData (http://xdata.fr) that aims at combining large (anonymized) datasets provided by different service providers (telecom, electricity, water man- agement, postal service, etc.).
AcsC14kdd.pdf (1.76 Mo) Télécharger le fichier
hal-01060070 , version 1 (02-09-2014)
  • HAL Id : hal-01060070 , version 1
Gergely Acs, Claude Castelluccia. A Case Study: Privacy Preserving Release of Spatio-temporal Density in Paris. KDD '14 Proceedings of the 20th ACM SIGKDD international conference on Knowledge discovery and data mining, ACM, Aug 2014, New York, United States. ⟨hal-01060070⟩
550 Consultations
735 Téléchargements
