Continuous gait cycle index estimation for electrical stimulation assisted foot drop correction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of NeuroEngineering and Rehabilitation Année : 2014
Background
Walking impairment after stroke can be addressed with the use of drop foot stimulators (DFS). Many studies have demonstrated that DFS improves walking speed, reduces spasticity and reduces the physiologic effort of walking. Current DFS, through activation of the common peroneal nerve, elicit ankle dorsiflexion during swing phase of gait. DFS are generally piloted by force sensing resistor placed in the shoe of the affected side with stimulation triggered ON by heel rise and triggered OFF by heel strike. A tilt sensor can also be used with stimulation triggered by the tilt of the shank of the affected leg. These triggering approaches are the standard for initiating stimulation. However, the real-time modulation of FES intensity to provide more optimized delivery of stimulation and also to regulate dorsiflexion in the presence of disturbances, such as fatigue and spasticity may increase the number of potential users of DFS. Concerning research domain, stimulators that would allow modulating the stimulation pattern in between heel rise and strike events would allow exploring new stimulation strategies. We propose to extract continuous information: the gait cycle index (GCI), from one inertial measurement unit (IMU) measuring shank tilt angle. In order to illustrate the use of this real-time information, we show the feasibility of piloting an electrical stimulator.
Methods
12 subjects with post-stroke hemiplegia participated. A wireless IMU was placed on the unaffected shank and was used to estimate GCI. Subjects performed 3 trials in each of the 3 conditions: C1 no stimulation aid, C2 electrical stimulation assistance triggered by heel switch, C3 electrical stimulation assistance triggered from GCI.
Results
1) the proposed algorithm was able to real-time estimate GCI, 2) events could be extracted from GCI information in order to trig a DFS.
Conclusion
The estimation of the continuous GCI in individuals with stroke is possible. Events can be extracted from this information in order to trig a stimulator. These results are a first step towards the possibility to investigate new DFS paradigms based on real-time modulation of stimulation parameters.
Neurobiologie
1743-0003-11-118.pdf (1.35 Mo) Télécharger le fichier
1743-0003-11-118.xml (79.28 Ko) Télécharger le fichier
Format : Autre
hal-01060086 , version 1 (02-09-2014)
Christine Azevedo Coste, Jovana Jovic, Roger Pissard-Gibollet, Jérôme Froger. Continuous gait cycle index estimation for electrical stimulation assisted foot drop correction. Journal of NeuroEngineering and Rehabilitation, 2014, 11 (1), pp.118. ⟨10.1186/1743-0003-11-118⟩. ⟨hal-01060086⟩
398 Consultations
284 Téléchargements
