Convergence of a splitting inertial proximal method for monotone operators, Journal of Computational and Applied Mathematics, vol.155, issue.2, pp.447-454, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00780778
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Proximal splitting methods in signal processing In Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
Signal recovery by proximal forward-backward splitting, Multiscale Model. Simul, vol.4, issue.4, pp.1168-1200, 2005. ,
On the Douglas???Rachford splitting method and the proximal point algorithm for maximal monotone operators, Mathematical Programming, vol.29, issue.1, pp.293-318, 1992. ,
DOI : 10.1007/BF01581204
A dual algorithm for the solution of nonlinear variational problems via finite element approximation, Computers & Mathematics with Applications, vol.2, issue.1, pp.17-40, 1976. ,
DOI : 10.1016/0898-1221(76)90003-1
New Proximal Point Algorithms for Convex Minimization, SIAM Journal on Optimization, vol.2, issue.4, pp.649-664, 1992. ,
DOI : 10.1137/0802032
Splitting Algorithms for the Sum of Two Nonlinear Operators, SIAM Journal on Numerical Analysis, vol.16, issue.6, pp.964-979, 1979. ,
DOI : 10.1137/0716071
An accelerated forward-backward algorithm for monotone inclusions. CoRR, abs/1403, 2014. ,
Problem complexity and method efficiency in optimization ,
A method for solving the convex programming problem with convergence rate, Dokl. Akad. Nauk SSSR, vol.269, issue.1 23, pp.543-547, 1983. ,
Introductory lectures on convex optimization, volume 87 of Applied Optimization, 2004. ,
Smooth minimization of non-smooth functions, Mathematical Programming, vol.269, issue.1, pp.127-152, 2005. ,
DOI : 10.1007/s10107-004-0552-5
Weak convergence of the sequence of successive approximations for nonexpansive mappings, Bull. Amer. Math. Soc, vol.73, pp.591-597, 1967. ,
On accelerated proximal gradient methods for convexconcave optimization, 2008. ,
