Conference papers
Incommensurability and Multi-paradigm Grounding in Design Science Research: Implications for Creating Knowledge
Abstract : The problem identification-design-build-evaluate-theorize structure of design science research has been proposed as an approach to creating knowledge in information systems and in broader organizational and social domains. Although the approach has merit, the philosophical foundations of two specific components warrant attention. First, the grounding of design theory on potentially incommensurate kernel theories may produce incoherent design theory. In addition, design theory has no strong logical connection to kernel theories, and so cannot be used to test or validate the contributing kernel theories. Second, the philosophical grounding of evaluation may inadvertently shift from functionally based measures of utility and efficiency, to evaluation based on the pragmatic fulfillment of multidimensional human actions as people encounter information systems, resulting in evaluation errors. Although design and evaluation from a single paradigm is not desirable, sufficient, or representative of design science research, multi-paradigm grounding of design and evaluation must be realized and used consciously by the research community if the design science approach is to remain a legitimate approach to knowledge creation.
Document type :
Conference papers
Complete list of metadata
Cited literature [52 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060391
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, September 4, 2014 - 12:59:33 PM
Last modification on : Thursday, March 5, 2020 - 4:47:05 PM
Long-term archiving on: : Friday, December 5, 2014 - 10:11:53 AM
File
318_02_Hovorka.pdf
Identifiers
Citation
Dirk S. Hovorka. Incommensurability and Multi-paradigm Grounding in Design Science Research: Implications for Creating Knowledge. IFIP WG 8.2/8.6 InternationalWorking Conference on Human Benefit through the Diffusion of Information Systems Design Science Research, Mar 2010, Perth, Australia. pp.13-27, ⟨10.1007/978-3-642-12113-5_2⟩. ⟨hal-01060391⟩
Share
Metrics
Record views
42
Files downloads
80
