Fuzzy Cognitive Map for Software Testing Using Artificial Intelligence Techniques
This paper discusses a framework to assist test managers to evaluate the use of AI techniques as a potential tool in software testing. Fuzzy Cognitive Maps (FCMs) are employed to evaluate the framework and make decision analysis easier. A what-if analysis is presented that explores the general application of the framework. Simulations are performed to show the effectiveness of the proposed method. The framework proposed is innovative and it assists managers in making efficient decisions.
