Application of dimensionality reduction in recommender systems -a case study, ACM WebKDD 2000 Web Mining for E-Commerce Workshop, pp.82-90, 2000. ,
DOI : 10.21236/ADA439541
Eigentaste: A constant time collaborative filtering algorithm, Information Retrieval, vol.4, issue.2, pp.133-151, 2001. ,
DOI : 10.1023/A:1011419012209
Latent semantic models for collaborative filtering, ACM Transactions on Information Systems, vol.22, issue.1, pp.89-115, 2004. ,
DOI : 10.1145/963770.963774
URL : http://mainline.brynmawr.edu/Courses/cs380/fall2006/p89-hofmann.pdf
Probabilistic matrix factorization, Advances in Neural Information Processing Systems, pp.1257-1264, 2008. ,
Scalable Collaborative Filtering with Jointly Derived Neighborhood Interpolation Weights, Seventh IEEE International Conference on Data Mining (ICDM 2007), pp.43-52, 2007. ,
DOI : 10.1109/ICDM.2007.90
URL : http://www.research.att.com/areas/visualization/papers_videos/pdf/DBLP-conf-icdm-BellK07.pdf
Scalable collaborative filtering approaches for large recommender systems, The Journal of Machine Learning Research, vol.10, pp.623-656, 2009. ,
Collaborative filtering based on iterative principal component analysis, Expert Systems with Applications, vol.28, issue.4, pp.823-830, 2005. ,
DOI : 10.1016/j.eswa.2004.12.037
Improving regularized singular value decomposition for collaborative filtering, Proceedings of 13th ACM International Conference on Knowledge Discovery and Data Mining (KDD'07), pp.39-42, 2007. ,
Nonlinear Principal Component Analysis and Related Techniques, Multiple Correspondence Analysis and Related Techniques, pp.107-133, 2006. ,
DOI : 10.1201/9781420011319.ch4
Mining performance data through nonlinear PCA with optimal scaling, Applied Stochastic Models in Business and Industry, vol.143, issue.1, pp.85-101, 2010. ,
DOI : 10.1108/09513549710186272
Principal Components Analysis With Nonlinear Optimal Scaling Transformations for Ordinal and Nominal Data, Handbook of Quantitative Methods in the Social Sciences, pp.49-70, 2004. ,
DOI : 10.4135/9781412986311.n3
The Gifi system of descriptive multivariate analysis, Statistical Science, vol.13, issue.4, pp.307-336, 1998. ,
DOI : 10.1214/ss/1028905828
Gifi methods for optimal scaling in r: The package homals, Journal of Statistical Software, vol.31, issue.4, pp.1-21, 2009. ,
