On the Problem of Attribute Selection for Software Cost Estimation: Input Backward Elimination Using Artificial Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many parameters affect the cost evolution of software projects. In the area of software cost estimation and project management the main challenge is to understand and quantify the effect of these parameters, or 'cost drivers', on the effort expended to develop software systems. This paper aims at investigating the effect of cost attributes on software development effort using empirical databases of completed projects and building Artificial Neural Network (ANN) models to predict effort. Prediction performance of various ANN models with different combinations of inputs is assessed in an attempt to reduce the models' input dimensions. The latter is performed by using one of the most popular saliency measures of network weights, namely Garson's Algorithm. The proposed methodology provides an insight on the interpretation of ANN which may be used for capturing nonlinear interactions between variables in complex software engineering environments.
PapatheocharousA10.pdf (479.55 Ko) Télécharger le fichier
hal-01060679 , version 1 (17-11-2017)
Paternité
Efi Papatheocharous, Andreas S. Andreou. On the Problem of Attribute Selection for Software Cost Estimation: Input Backward Elimination Using Artificial Neural Networks. 6th IFIP WG 12.5 International Conference on Artificial Intelligence Applications and Innovations (AIAI), Oct 2010, Larnaca, Cyprus. pp.287-294, ⟨10.1007/978-3-642-16239-8_38⟩. ⟨hal-01060679⟩
73 Consultations
67 Téléchargements
