Dynamic load balancing in parallel queueing systems: Stability and optimal control, European Journal of Operational Research, vol.168, issue.2, pp.509-519, 2006. ,
DOI : 10.1016/j.ejor.2004.04.041
URL : http://www-personal.engin.umich.edu/~melewis/pubs/load.pdf
Optimality of the shortest line discipline, Journal of Applied Probability, vol.14, issue.01, pp.181-190, 1977. ,
DOI : 10.2307/3212561
An approximation for the mean response time for shortest queue routing with general interarrival and service times, Performance Evaluation, vol.17, issue.2, pp.123-162, 1993. ,
DOI : 10.1016/0166-5316(93)90004-E
An approximation to the response time for shortest queue routing. Perform Eval, pp.181-190, 1989. ,
Bounding the mean response time of a minimum expected delay routing system: an algorithmic approach, IEEE Trans Comput, pp.1371-82, 1995. ,
Optimal control of a queueing system with two heterogeneous servers, IEEE Transactions on Automatic Control, vol.29, issue.8, pp.696-703, 1984. ,
DOI : 10.1109/TAC.1984.1103637
A simple proof of the optimality of a threshold policy in a two-server queueing system, Systems & Control Letters, vol.26, issue.5, pp.301-303, 1995. ,
DOI : 10.1016/0167-6911(95)00015-1
Critical Thresholds for Dynamic Routing in Queueing Networks, Queueing Systems, pp.297-316, 2002. ,
A two-queue and two-server model with a threshold-based control service policy, European Journal of Operational Research, vol.137, issue.3, pp.593-611, 2002. ,
DOI : 10.1016/S0377-2217(01)00139-4
Equilibrium threshold strategies in observable queueing systems with setup/closedown times, DOI: 10.1007, pp.10100-10109, 2009. ,
DOI : 10.1007/978-1-4615-0359-0
Optimality of a Threshold Policy in theM/M/ queue with repeated vacations, Mathematical Methods of Operations Research, vol.14, issue.6, pp.75-96, 1996. ,
DOI : 10.2307/3006802
Applications of queuing theory, Industrial engineering handbook, Fifth edition, pp.67-78, 2001. ,
Stochastic Processes Occurring in the Theory of Queues and their Analysis by the Method of the Imbedded Markov Chain, The Annals of Mathematical Statistics, vol.24, issue.3, pp.360-369, 1953. ,
DOI : 10.1214/aoms/1177728975
