Vector Sensor Arrays in Underwater Acoustic Applications - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
(1) , (1) , (1)
1
Traditionally, ocean acoustic signals have been acquired using hydrophones, which measure the pressure field and are typically omnidirectional. A vector sensor measures both the acoustic pressure and the three components of particle velocity. Assembled into an array, a vector sensor array (VSA) improves spatial filtering capabilities when compared with arrays of same length and same number of hydrophones. The objective of this work is to show the advantage of the use of vector sensors in underwater acoustic applications such as direction of arrival (DOA) estimation and geoacoustic inversion. Beyond the improvements in DOA estimation, it will be shown the advantages of using the VSA in bottom parameters estimation. Additionally, is tested the possibility of using high frequency signals (say 8-14 kHz band), acquired during the MakaiEx 2005, to allow a small aperture array, reducing the cost of actual sub-bottom profilers and providing a compact and easy-to-deploy system.
SantosFJ10.pdf (600.11 Ko) Télécharger le fichier
Dates and versions
hal-01060754 , version 1 (16-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Paulo Santos, Paulo Felisberto, Sérgio M. Jesus. Vector Sensor Arrays in Underwater Acoustic Applications. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.315-322, ⟨10.1007/978-3-642-11628-5_34⟩. ⟨hal-01060754⟩
67 View
506 Download
Share
