An Approach to Modification of Water Flow Algorithm for Segmentation and Text Parameters Extraction - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
This paper proposes an approach to water flow method modification for text segmentation and reference text line detection of sample text at almost any skew angle. Original water flow algorithm assumes hypothetical water flows under only a few specified angles of the document image frame from left to right and vice versa. As a result of water flow algorithm, unwetted image frames are extracted. These areas are of major importance for text line parameters extraction as well as for text segmentation. Water flow method modification means extension values of water flow specified angle and unwetted image frames function enlargement. Modified method is examined and evaluated under different sample text skew angles. Results are encouraged especially due to improving text segmentation which is the most challenging process stage.
BrodicM10.pdf (216.99 Ko) Télécharger le fichier
Dates and versions
hal-01060755 , version 1 (17-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Darko Brodić, Zoran Milivojević. An Approach to Modification of Water Flow Algorithm for Segmentation and Text Parameters Extraction. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.323-330, ⟨10.1007/978-3-642-11628-5_35⟩. ⟨hal-01060755⟩
49 View
49 Download
Share
