Analysis of distribution network protection issues in presence of dispersed generation. Electrical Power Systems Research 79, pp.49-56, 2009. ,
Short-circuit calculations in networks with distributed generation, Electric Power Systems Research, vol.78, issue.7, pp.1181-1191, 2008. ,
DOI : 10.1016/j.epsr.2007.10.003
Technical impacts of small distributed generation units on LV networks, 2003 IEEE Power Engineering Society General Meeting (IEEE Cat. No.03CH37491), pp.2459-2464, 2003. ,
DOI : 10.1109/PES.2003.1271027
Integration of fast acting electronic fault current limiters (EFCL) in medium voltage systems, CIRED 17th International Conference on Electricity Distribution, 2003. ,
Reverse Engineering of Inductive Fault Current Limiters. Accepted for publication, 9th European Conference on Applied Superconductivity, 2009. ,
A study on DC S/N transition type superconducting fault current limiting interrupter, IEEE Transactions on Appiled Superconductivity, vol.13, issue.2 ,
DOI : 10.1109/TASC.2003.812985
Superconductivity 13, pp.2088-2091, 2003. ,
Investigation of high-Tc bulk material for its use in resistive superconducting fault current limiters, IEEE Transactions on Appiled Superconductivity, vol.11, issue.1, pp.1960-1963, 2001. ,
DOI : 10.1109/77.920236
Fault current limiter based on high temperature superconductors ??? different concepts, test results, simulations, applications, Physica C: Superconductivity, vol.354, issue.1-4, pp.27-33, 2001. ,
DOI : 10.1016/S0921-4534(01)00018-1
Proposal of flux flow resistance type fault current limiter using Bi2223 high T/sub c/ superconducting bulk, IEEE Transactions on Appiled Superconductivity, vol.12, issue.1, pp.876-879, 2002. ,
DOI : 10.1109/TASC.2002.1018540
CURL 10: Development and Field-Test of a 10 kV/10 MVA Resistive Current Limiter Based on Bulk MCP-BSCCO 2212, IEEE Transactions on Appiled Superconductivity, vol.15, issue.2, pp.1955-1960, 2005. ,
DOI : 10.1109/TASC.2005.849344
kV single-phase superconducting fault current limiter based on YBCO films, Cryogenics, vol.14, issue.47, pp.183-188, 2007. ,
DOI : 10.1016/j.cryogenics.2006.12.003
Superconducting fault current limiter using high-resistive YBCO tapes, Physica C: Superconductivity, vol.468, issue.15-20, pp.2046-2049, 2008. ,
DOI : 10.1016/j.physc.2008.05.123
Current-limiting reactor based on high-T/sub c/ superconductors, IEEE Transactions on Magnetics, vol.27, issue.2, pp.1089-1092, 1991. ,
DOI : 10.1109/20.133370
Test of 1.2 MVA high- superconducting fault current limiter, Superconductor Science and Technology, vol.10, issue.12, pp.914-918, 1997. ,
DOI : 10.1088/0953-2048/10/12/011
URL : https://hal.archives-ouvertes.fr/hal-01466197
HTS Components for High Voltage Resistive Current Limiters Based on a Magnetic Field Triggered Concept, IEEE Transactions on Applied Superconductivity, vol.17, issue.2, pp.1772-1775, 2007. ,
DOI : 10.1109/TASC.2007.898405
