Interconnections between Reliability, Maintenance and Availability
The assurance of power quality depends on factors
which influence the performances of the availability: the reliability
and its support - the maintenance. This paper deals with the
interactions between the indicators of reliability, maintenance,
availability and with the methods for the calculation of the reliability
indicators. For an overhead line of 110 kV the characteristics of the
reliability of the system are determined by modeling and analyzing its
functionality by the Markov process of continuous time. The value of the
availability index and the maintenance function function contributes to
ascertain for the studied case that the value of the availability
coefficient has the same value with the probability of success and the
probability of repairing an equipment is closely connected to the
maintenance function.
Bibliothèque électronique [cs.DL]
