Hybrid Photovoltaic-Thermal Collectors: A Review
Solar energy can be converted directly into electric
and thermal energy through photovoltaic cells and thermal collectors,
respectively. However this conversion, in particular the photovoltaic,
has a reduced efficiency. A solution proposed to increase this
efficiency is with the hybrid solar structure, which consists in the
junction of the photovoltaic panel and the thermal collector in a single
module. The interest on these solar systems led the International Energy
Agency to create a "Task" on this subject. This paper presents a review
of the research in this area, presenting the definitions of the related
collectors and results of their characteristics, as well as some ideas
for future studies.
