Robust Position Control of a DC Motor by Sliding Mode - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The position of the DC motor is controlled by using a continuous sliding mode control (SMC), which is highly robust to the Coulomb friction torque and to high unknown payload variations, which involve changes in the rotational inertia of the motor shaft. The main contribution of the work is the experimentation of a SMC control which does not requires the knowledge of the payload variation range, i.e., the system is quite robust to any unknown change in the payload mass value.
MamaniBB10.pdf (252.29 Ko) Télécharger le fichier
hal-01060775 , version 1 (16-11-2017)
Paternité
Gabriela Mamani, Jonathan Becedas, Vicente Feliu Batlle. Robust Position Control of a DC Motor by Sliding Mode. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.493-502, ⟨10.1007/978-3-642-11628-5_55⟩. ⟨hal-01060775⟩
138 Consultations
626 Téléchargements
