Abstract : Taking into consideration the development and
integration of electrical machines with lower dimensions and higher
performance, this paper presents the design and development of a
three-phase axial flux disc motor, with 50 Hz frequency supply. It is
made with two conventional semi-stators and a rotor, which can be
implemented with a conventional aluminum disc or a high
temperature-superconducting disc. The analysis of the motor
characteristics is done with a 2D commercial finite elements package,
being the modeling performed as a linear motor. The obtained results
allow concluding that the superconductor motor provides a higher force
than the conventional one. The conventional disc motor presents an
asynchronous behavior, like a conventional induction motor, while the
superconductor motor presents both synchronous and asynchronous
behaviors.
Luis M. Camarinha-Matos; Pedro Pereira; Luis Ribeiro. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. Springer, IFIP Advances in Information and Communication Technology, AICT-314, pp.503-510, 2010, Emerging Trends in Technological Innovation. 〈10.1007/978-3-642-11628-5_56〉
https://hal.inria.fr/hal-01060776
Contributeur : Hal Ifip
Soumis le : jeudi 23 novembre 2017 - 16:24:09
Dernière modification le : mercredi 29 novembre 2017 - 12:06:23
David Inácio, João Martins, Mário Ventim Neves, Alfredo Álvarez, Amadeu Leão Rodrigues. Disc Motor: Conventional and Superconductor
Simulated Results Analysis. Luis M. Camarinha-Matos; Pedro Pereira; Luis Ribeiro. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. Springer, IFIP Advances in Information and Communication Technology, AICT-314, pp.503-510, 2010, Emerging Trends in Technological Innovation. 〈10.1007/978-3-642-11628-5_56〉. 〈hal-01060776〉
