Disc Motor: Conventional and Superconductor Simulated Results Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Taking into consideration the development and integration of electrical machines with lower dimensions and higher performance, this paper presents the design and development of a three-phase axial flux disc motor, with 50 Hz frequency supply. It is made with two conventional semi-stators and a rotor, which can be implemented with a conventional aluminum disc or a high temperature-superconducting disc. The analysis of the motor characteristics is done with a 2D commercial finite elements package, being the modeling performed as a linear motor. The obtained results allow concluding that the superconductor motor provides a higher force than the conventional one. The conventional disc motor presents an asynchronous behavior, like a conventional induction motor, while the superconductor motor presents both synchronous and asynchronous behaviors.
InacioMNAR10.pdf (312.55 Ko) Télécharger le fichier
hal-01060776 , version 1 (23-11-2017)
Paternité
David Inácio, João Martins, Mário Ventim Neves, Alfredo Álvarez, Amadeu Leão Rodrigues. Disc Motor: Conventional and Superconductor Simulated Results Analysis. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.503-510, ⟨10.1007/978-3-642-11628-5_56⟩. ⟨hal-01060776⟩
99 Consultations
92 Téléchargements
