A New Automated Trigger Circuit for a Pulsed Nd: YAG Laser - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The power supply of flash lamp-pumped a Nd: YAG solid-state laser basically consists of a trigger circuit which initiate the ionization of the gas into the lamp, a simmer circuit that keeps the ionized gas with a low-level dc current and a main discharge circuit where a storage capacitor is discharged into a flash lamp to pump the Nd:YAG laser. The impedance of the flash lamp presents a nonlinear variation and the gas deionization which can occur between two pulses laser, leading to another manual triggering operation. To overcome this operation, we give in this paper a new automated trigger circuit activated by a delivered signal from the simmer circuit. This circuit is simple for implementation and need just few components. It has been simulated by PSpice software and validated by experimental results.
AlmabouadaLHNB10.pdf (119.67 Ko) Télécharger le fichier
hal-01060782 , version 1 (16-11-2017)
Paternité
Fatah Almabouada, Djelloul Louhibi, Abderrahmane Haddouche, Abdelkader Noukaz, Ramdan Beggar. A New Automated Trigger Circuit for a Pulsed Nd: YAG Laser. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.557-564, ⟨10.1007/978-3-642-11628-5_62⟩. ⟨hal-01060782⟩
119 Consultations
1297 Téléchargements
