The TSTS Method in Cultural Heritage Search - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In cultural heritage content management systems in which cultural objects are described with the use of their semantic, temporal and spatial properties, the search capabilities taking all those properties into consideration are very limited. The difficulty comes from the fact that concepts evolve over time and depend on location. In this paper the TSTS search method is presented based on the TST similarity measure that allows assessing the similarity factor between different resources in a knowledgebase. A ranked search result is generated basing on the semantic distance between the fuzzy set created for the user query and fuzzy sets describing potential results in the time-space continuum.
StawniakC10.pdf (85.78 Ko) Télécharger le fichier
hal-01060787 , version 1 (17-11-2017)
Paternité
Mirosław Stawniak, Wojciech Cellary. The TSTS Method in Cultural Heritage Search. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.43-50, ⟨10.1007/978-3-642-11628-5_5⟩. ⟨hal-01060787⟩
32 Consultations
57 Téléchargements
