Delay Analysis for TDMA Schemes with Packet Recombining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers the use of SC modulations (Single-Carrier) with FDE (Frequency-Domain Equalization) with low-complexity soft combining ARQ schemes (Automatic Repeat reQuest). With our technique, packets associated to different transmission attempts are combined in a soft way, allowing improved performances. Its low complexity makes it particularly interesting for the uplink of wireless systems. This paper proposes an accurate analytical model for a TDMA (Time Division Multiple Access) scheme where packet combining ARQ is applied. It evaluates the uplink non-saturated packet delay for a generic message arrival process. Our analytical results are validated using physical and MAC layer simulations.
PereiraBDOCP10.pdf (221.65 Ko) Télécharger le fichier
hal-01060811 , version 1 (17-11-2017)
Paternité
Miguel Pereira, Luís Bernardo, Rui Dinis, Rodolfo Oliveira, Paulo Carvalho, et al.. Delay Analysis for TDMA Schemes with Packet Recombining. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.261-270, ⟨10.1007/978-3-642-11628-5_28⟩. ⟨hal-01060811⟩
112 Consultations
97 Téléchargements
