tmLQCD: A program suite to simulate Wilson twisted mass lattice QCD, Computer Physics Communications, vol.180, issue.12, pp.2717-2738, 2009. ,
DOI : 10.1016/j.cpc.2009.05.016
Equation of state and magnetic susceptibility of N f = 2 + 1 QCD with physical quark masses. arXiv:1310 ,
URL : https://hal.archives-ouvertes.fr/hal-00879639
Some efficient solutions to the affine scheduling problem. I. One-dimensional time, International Journal of Parallel Programming, vol.40, issue.6, pp.313-347, 1992. ,
DOI : 10.1007/BF01407835
Some efficient solutions to the affine scheduling problem. Part II. Multidimensional time, International Journal of Parallel Programming, vol.2, issue.4, p.389420, 1992. ,
DOI : 10.1007/BF01379404
Scheduling affine parameterized recurrences by means of variable dependent timing functions, Proceedings of the International Conference on Application Specific Array Processing, pp.100-110, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00075354
Optimizing memory usage in the polyhedral model, ACM Transactions on Programming Languages and Systems (TOPLAS), vol.22, issue.5, pp.773-815, 2000. ,
Precise Management of Scratchpad Memories for Localising Array Accesses in Scientific Codes, Compiler Construction, pp.236-250, 2009. ,
DOI : 10.1007/978-3-642-00722-4_17
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., pp.75-86, 2004. ,
DOI : 10.1109/CGO.2004.1281665
Clang: A C Language Family Frontend for LLVM ,
POLLY ??? PERFORMING POLYHEDRAL OPTIMIZATIONS ON A LOW-LEVEL INTERMEDIATE REPRESENTATION, Parallel Processing Letters, vol.22, issue.04, 2012. ,
DOI : 10.1142/S0129626412500107
isl: An Integer Set Library for the Polyhedral Model, Mathematical SoftwareICMS 2010, pp.299-302, 2010. ,
DOI : 10.1007/978-3-642-15582-6_49
The rise and fall of High Performance Fortran, Proceedings of the third ACM SIGPLAN conference on History of programming languages , HOPL III, p.71722, 2007. ,
DOI : 10.1145/1238844.1238851
Using integer sets for data-parallel program analysis and optimization, ACM SIGPLAN Notices, vol.33, issue.5, pp.186-198, 1998. ,
DOI : 10.1145/277652.277721
The Omega calculator and library, version 1.1.0. College Park, pp.20742-20760, 1996. ,
Communication optimization and code generation for distributed memory machines, ACM SIGPLAN Notices, vol.28, issue.6, pp.126-138, 1993. ,
DOI : 10.1145/173262.155102
Generating efficient data movement code for heterogeneous architectures with distributed-memory, Parallel Architectures and Compilation Techniques (PACT), 2013 22nd International Conference on, pp.375-386, 2013. ,
Automatic Distributed-Memory Parallelization and Code Generation using the Polyhedral Framework ,
Automatic code generation for distributed memory architectures in the polytope model, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, p.7, 2006. ,
DOI : 10.1109/IPDPS.2006.1639500
Memory Allocations for Tiled Uniform Dependence Programs, IMPACT, vol.2013, p.13, 2013. ,
Code generation for parallel execution of a class of irregular loops on distributed memory systems, 2012 International Conference for High Performance Computing, Networking, Storage and Analysis, p.72, 2012. ,
DOI : 10.1109/SC.2012.30
A Programming Guide to ZPL, Scientific and Engineering Computation Series, 1999. ,
Improving Data Locality by Chunking, CC'12 International Conference on Compiler Construction, pp.320-335, 2003. ,
DOI : 10.1007/3-540-36579-6_23
URL : https://hal.archives-ouvertes.fr/inria-00001055
A practical automatic polyhedral parallelizer and locality optimizer, ACM SIGPLAN Notices, vol.43, issue.6, pp.101-113, 2008. ,
DOI : 10.1145/1379022.1375595
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
