New interface
Conference papers
Discrimination of visual pedestrians data by combining projection and prediction learning
Abstract : PROPRE is a generic and semi-supervised neural learning paradigm that extracts meaningful concepts of multimodal data flows based on predictability across modalities. It consists on the combination of two computational paradigms. First, a topological projection of each data flow on a self-organizing map (SOM) to reduce input dimension. Second, each SOM activity is used to predict activities in all other SOMs. Predictability measure, that compares predicted and real activities, is used to modulate the SOM learning to favor mutually predictable stimuli. In this article, we study PROPRE applied to a classical visual pedestrian data classification task. The SOM learning modulation introduced in PROPRE improves significantly classification performance.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01061654
Contributor : Mathieu Lefort Connect in order to contact the contributor
Submitted on : Monday, September 8, 2014 - 10:45:31 AM
Last modification on : Wednesday, May 11, 2022 - 3:20:02 PM
Long-term archiving on: : Tuesday, December 9, 2014 - 11:45:41 AM
File
article.pdf
Identifiers
  • HAL Id : hal-01061654, version 1
Collections
Citation
Mathieu Lefort, Alexander Gepperth. Discrimination of visual pedestrians data by combining projection and prediction learning. European Symposium on artificial neural networks (ESANN), Apr 2014, Bruges, Belgium. ⟨hal-01061654⟩
Share
Metrics
Record views
135
Files downloads
39
