Conference papers
Design of Intelligent Hydraulic Excavator Control System Based on PID Method
Abstract : Most of the domestic designed hydraulic excavators adopt the constant power design method and set 85%~90% of engine power as the hydraulic system adoption power, it causes high energy loss due to mismatching of power between the engine and the pump. While the variation of the rotational speed of engine could sense the power shift of the load, it provides a new method to adjust the power matching between engine and pump through engine speed. Based on negative flux hydraulic system, an intelligent hydraulic excavator control system was designed based on rotational speed sensing method to improve energy efficiency. The control system was consisted of engine control module, pump power adjusted module, engine idle module and system fault diagnosis module. Special PLC with CAN bus was used to acquired the sensors and adjusts the pump absorption power according to load variation. Four energy saving control strategies with constant power method were employed to improve the fuel utilization. Three power modes (H, S and L mode) were designed to meet different working status; Auto idle function was employed to save energy through two work status detected pressure switches, 1300rpm was setting as the idle speed according to the engine consumption fuel curve. Transient overload function was designed for deep digging within short time without spending extra fuel. An increasing PID method was employed to realize power matching between engine and pump, the rotational speed's variation was taken as the PID algorithm's input; the current of proportional valve of variable displacement pump was the PID's output. The result indicated that the auto idle could decrease fuel consumption by 33.33% compared to work in maximum speed of H mode, the PID control method could take full use of maximum engine power at each power mode and keep the engine speed at stable range. Application of rotational speed sensing method provides a reliable method to improve the excavator's energy efficiency and realize power match between pump and engine.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01061733
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, September 8, 2014 - 1:25:50 PM
Last modification on : Tuesday, June 1, 2021 - 5:00:01 PM
Long-term archiving on: : Tuesday, December 9, 2014 - 11:56:06 AM
File
0430--Jun_Zhang.pdf
Identifiers
Citation
Jun Zhang, Shengjie Jiao, Xiaoming Liao, Penglong yin, yulin Wang, et al.. Design of Intelligent Hydraulic Excavator Control System Based on PID Method. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.207-215, ⟨10.1007/978-3-642-12220-0_31⟩. ⟨hal-01061733⟩
Share
Metrics
Record views
134
Files downloads
1960
