Knot segmentation in 3D CT images of wet wood - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2014
This paper proposes a fully automatic method to segment wood knots from images obtained by an X-ray Computed Tomography scanner. Wood knot segmentation is known to be a difficult problem in the presence of sapwood because of the quite similar density of knots and wet sapwood. Classical segmentation techniques produce unsatisfactory results due to the very weak distinction between these two intensities. To overcome this limitation caused by physical characteristics, we propose to exploit the geometric properties of both the knot shapes and knot-sapwood interface. Based on previous work related to automatic knot detection, a new segmentation algorithm is proposed that uses a robust curvature estimation of 2D digital contours. The segmentation process is fast, easily parallelizable and produces better segmentation results than other state-of-the-art algorithms. It may be reproduced from the precise description given here or from source code available online.
Fichier non déposé
hal-01062639 , version 1 (10-09-2014)
Paternité - Partage selon les Conditions Initiales
Adrien Krähenbühl, Bertrand Kerautret, Isabelle Debled-Rennesson, Frédéric Mothe, Fleur Longuetaud. Knot segmentation in 3D CT images of wet wood. Pattern Recognition, 2014, 47 (12), pp.3852-3869. ⟨10.1016/j.patcog.2014.05.015⟩. ⟨hal-01062639⟩
335 Consultations
0 Téléchargements
