Computational Protein Design as a Cost Function Network Optimization Problem, Proceedings of the 18th Int. Conf. on Principles and Practice of Constraint Programming, pp.840-849, 2012. ,
DOI : 10.1007/978-3-642-33558-7_60
URL : https://hal.archives-ouvertes.fr/hal-01191320
An optimal coarse-grained arc consistency algorithm, Artificial Intelligence, vol.165, issue.2, pp.165-185, 2005. ,
DOI : 10.1016/j.artint.2005.02.004
Arc consistency for soft constraints, Artificial Intelligence, vol.154, issue.1-2, pp.199-227, 2004. ,
DOI : 10.1016/j.artint.2003.09.002
A Comparison of CLP(FD) and ASP Solutions to NP-Complete Problems, Proc of International Conference on Logic Programming, pp.67-82, 2005. ,
DOI : 10.1007/11562931_8
osprey, Methods Enzymol, vol.523, p.87, 2013. ,
DOI : 10.1016/B978-0-12-394292-0.00005-9
Protein Design Using Continuous Rotamers, PLoS Computational Biology, vol.285, issue.1, p.2012 ,
DOI : 10.1371/journal.pcbi.1002335.s002
URL : http://doi.org/10.1371/journal.pcbi.1002335
On the Implementation of Weight Constraint Rules in Conflict-Driven ASP Solvers, Logic Programming, pp.250-264, 2009. ,
DOI : 10.1007/978-3-540-24605-3_37
Clingo= asp+ control: Preliminary report. arXiv preprint, 2014. ,
Protein design using answer set programming, Master Dissertation Instituto superior tecnico Lisboa, 2012. ,
Dead-end elimination with perturbations (deeper): A provable protein design algorithm with continuous sidechain and backbone flexibility, Proteins: Structure, Function, and Bioinformatics, vol.81, issue.1, pp.18-39, 2013. ,
A gradient-directed Monte Carlo approach for protein design, Journal of Computational Chemistry, vol.6, issue.11, pp.312164-2168, 2010. ,
DOI : 10.1002/jcc.21506
De novo protein design using pairwise potentials and a genetic algorithm, Protein Science, vol.3, issue.4, pp.567-574, 1994. ,
Backbone-dependent Rotamer Library for Proteins Application to Side-chain Prediction, Journal of Molecular Biology, vol.230, issue.2, pp.543-574, 1993. ,
DOI : 10.1006/jmbi.1993.1170
Practically useful: What the rosetta protein modeling suite can do for you, Biochemistry, issue.14, pp.492987-2998, 2010. ,
Improved prediction of protein side-chain conformations with SCWRL4, Proteins: Structure, Function, and Bioinformatics, vol.3, issue.Pt 1, pp.778-795, 2009. ,
DOI : 10.1002/prot.22488
Solving weighted CSP by maintaining arc consistency, Artificial Intelligence, vol.159, issue.1-2, pp.1-26, 2004. ,
DOI : 10.1016/j.artint.2004.05.004
Exploring the conformational space of protein side chains using dead-end elimination and the A* algorithm, Proteins Structure Function and Genetics, vol.33, issue.2, pp.227-239, 1998. ,
Rosetta3, Methods in Enzymology, vol.487, pp.545-574, 2011. ,
DOI : 10.1016/B978-0-12-381270-4.00019-6
What is answer set programming?, pp.1594-1597, 2008. ,
Engineering a mevalonate pathway in escherichia coli for production of terpenoids, Nature biotechnology, vol.21, issue.7, pp.796-802, 2003. ,
Sat-based protein design, ICCAD, pp.128-135, 2009. ,
Protein engineers turned evolutionists, Nature Methods, vol.103, issue.12, pp.991-994, 2007. ,
DOI : 10.1038/nmeth1207-991
Protein design is np-hard, Protein Engineering, vol.15, issue.10, pp.779-782, 2002. ,
Protein design in metabolic engineering and synthetic biology, Current Opinion in Biotechnology, vol.22, issue.5, pp.611-617, 2011. ,
DOI : 10.1016/j.copbio.2011.03.004
Iterative approach to computational enzyme design, Proceedings of the National Academy of Sciences, vol.109, issue.10, pp.3790-3795, 2012. ,
DOI : 10.1073/pnas.1118082108
Using genetic algorithm to design protein sequence, Appl.Math.Comput, vol.200, issue.1, pp.1-9, 2008. ,
A smoothed backbonedependent rotamer library for proteins derived from adaptive kernel density estimates and regressions, Structure, vol.19, issue.6, pp.844-858, 2011. ,
A new framework for computational protein design through cost function network optimization, Bioinformatics, vol.29, issue.17, pp.292129-292165, 2013. ,
DOI : 10.1093/bioinformatics/btt374
Mixed-Integer Linear Programming Algorithm for a Computational Protein Design Problem, Industrial & Engineering Chemistry Research, vol.46, issue.3, pp.839-845, 2007. ,
DOI : 10.1021/ie0605985
