Non-Rigid Registration meets Surface Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Non rigid registration is an important task in computer vision with many applications in shape and motion modeling. A fundamental step of the registration is the data association between the source and the target sets. Such association proves difficult in practice, due to the discrete nature of the information and its corruption by various types of noise, e.g. outliers and missing data. In this paper we investigate the benefit of the implicit representations for the non-rigid registration of 3D point clouds. First, the target points are described with small quadratic patches that are blended through partition of unity weighting. Then, the discrete association between the source and the target can be replaced by a continuous distance field induced by the interface. By combining this distance field with a proper deformation term, the registration energy can be expressed in a linear least square form that is easy and fast to solve. This significantly eases the registration by avoiding direct association between points. Moreover, a hierarchical approach can be easily implemented by employing coarse-to-fine representations. Experimental results are provided for point clouds from multi-view data sets. The qualitative and quantitative comparisons show the outperformance and robustness of our framework.
3DV_final (2).pdf (5.04 Mo) Télécharger le fichier
hal-01063513 , version 1 (15-09-2014)
hal-01063513 , version 2 (19-09-2014)
hal-01063513 , version 3 (21-10-2014)
Mohammad Rouhani, Edmond Boyer, Angel D. Sappa. Non-Rigid Registration meets Surface Reconstruction. 3DV 2014 - International Conference on 3D Vision, Dec 2014, Tokyo, Japan. pp.617-624, ⟨10.1109/3DV.2014.80⟩. ⟨hal-01063513v3⟩
436 Consultations
799 Téléchargements
