Performance capture from sparse multi-view ,
Optimal Step Nonrigid ICP Algorithms for Surface Registration, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2004. ,
DOI : 10.1109/CVPR.2007.383165
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
The 3L algorithm for fitting implicit polynomial curves and surfaces to data, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.22, issue.3, pp.298-313, 2000. ,
DOI : 10.1109/34.841760
Principal warps: thin-plate splines and the decomposition of deformations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.6, pp.567-585, 1989. ,
DOI : 10.1109/34.24792
Adaptive Space Deformations Based on Rigid Cells, Computer Graphics Forum, vol.24, issue.3, pp.339-347, 2007. ,
DOI : 10.1111/j.1467-8659.2007.01056.x
Free-form mesh tracking: A patch-based approach, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.1339-1346, 2008. ,
DOI : 10.1109/CVPR.2010.5539814
URL : https://hal.archives-ouvertes.fr/inria-00568909
Probabilistic Deformable Surface Tracking from Multiple Videos, ECCV, pp.326-339, 2010. ,
DOI : 10.1007/978-3-642-15561-1_24
URL : https://hal.archives-ouvertes.fr/inria-00568912
Global registration of dynamic range scans for articulated model reconstruction, ACM Transactions on Graphics, vol.30, issue.3, p.26, 2011. ,
DOI : 10.1145/1966394.1966405
Object modelling by registration of multiple range images, Image and Vision Computing, vol.10, issue.3, pp.145-155, 1992. ,
DOI : 10.1016/0262-8856(92)90066-C
A new point matching algorithm for non-rigid registration, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.114-141, 2003. ,
DOI : 10.1016/S1077-3142(03)00009-2
Robust registration of 2D and 3D point sets, Image and Vision Computing, vol.21, issue.13-14, pp.13-141145, 2001. ,
DOI : 10.1016/j.imavis.2003.09.004
Non-Rigid Registration Under Isometric Deformations, Computer Graphics Forum, vol.26, issue.3, pp.1449-1457, 2008. ,
DOI : 10.1111/j.1467-8659.2008.01285.x
Shape registration in implicit spaces using information theory and free form deformations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.8, pp.1303-1318, 2006. ,
DOI : 10.1109/TPAMI.2006.171
URL : https://hal.archives-ouvertes.fr/hal-00133233
Robust Point Set Registration Using Gaussian Mixture Models, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.8, pp.1633-1645, 2008. ,
DOI : 10.1109/TPAMI.2010.223
Using spin images for efficient object recognition in cluttered 3D scenes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.5, pp.433-449, 1999. ,
DOI : 10.1109/34.765655
3d non-rigid registration for mpu implicit surfaces, pp.1-8, 2008. ,
Pose space deformation, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.165-172, 2000. ,
DOI : 10.1145/344779.344862
Robust singleview geometry and motion reconstruction, ACM TOG, vol.28, issue.2, p.3, 2009. ,
Global Correspondence Optimization for Non-Rigid Registration of Depth Scans, Computer Graphics Forum, vol.26, issue.3, pp.1421-1430, 2008. ,
DOI : 10.1111/j.1467-8659.2008.01282.x
Non-Rigid Image Registration using a Hierarchical Partition of Unity Finite Element Method, 2007 IEEE 11th International Conference on Computer Vision, pp.1-8, 2007. ,
DOI : 10.1109/ICCV.2007.4409078
URL : https://hal.archives-ouvertes.fr/hal-00701414
Shape Representation and Registration in Vector Implicit Spaces: Adopting a Closed-Form Solution in the Optimization Process, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.35, issue.3, pp.763-768, 2013. ,
DOI : 10.1109/TPAMI.2012.245
Point Set Registration: Coherent Point Drift, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.12, pp.2262-2275, 2010. ,
DOI : 10.1109/TPAMI.2010.46
URL : http://arxiv.org/abs/0905.2635
Multi-level partition of unity implicits, ACM Transactions on Graphics, vol.22, issue.3, pp.463-470, 2003. ,
DOI : 10.1145/882262.882293
Non-rigid Shape Registration: A Single Linear Least Squares Framework, ECCV, pp.264-277, 2008. ,
DOI : 10.1007/978-3-642-33786-4_20
The Richer Representation the Better Registration, IEEE Transactions on Image Processing, vol.22, issue.12, pp.5036-5049, 2005. ,
DOI : 10.1109/TIP.2013.2281427
URL : https://hal.archives-ouvertes.fr/hal-00916505
Surface Deformation Models for Nonrigid 3D Shape Recovery, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.8, pp.1481-1487, 2007. ,
DOI : 10.1109/TPAMI.2007.1080
Correspondence-Less Non-rigid Registration of Triangular Surface Meshes, 2013 IEEE Conference on Computer Vision and Pattern Recognition, pp.2275-2282, 2013. ,
DOI : 10.1109/CVPR.2013.295
Free-form deformation of solid geometric models, pp.151-160, 1986. ,
A Concise and Provably Informative Multi-Scale Signature Based on Heat Diffusion, Computer Graphics Forum, vol.21, issue.6, pp.1383-1392, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01515.x
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.11, pp.1115-1138, 1991. ,
DOI : 10.1109/34.103273
Articulated mesh animation from multi-view silhouettes, ACM TOG, vol.27, issue.5 6, 2008. ,
A coarse-to-fine IP-driven registration for pose estimation from single ultrasound image, Computer Vision and Image Understanding, vol.117, issue.12, pp.1647-1658, 2013. ,
DOI : 10.1016/j.cviu.2013.01.015
