A categorization of robust speech processing datasets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2014
Speech and audio signal processing research is a tale of data collection efforts and evaluation campaigns. While large datasets for automatic speech recognition (ASR) in clean environments with various speaking styles are available, the landscape is not as picture- perfect when it comes to robust ASR in realistic environments, much less so for evaluation of source separation and speech enhancement methods. Many data collection efforts have been conducted, moving along towards more and more realistic conditions, each mak- ing different compromises between mostly antagonistic factors: financial and human cost; amount of collected data; availability and quality of annotations and ground truth; natural- ness of mixing conditions; naturalness of speech content and speaking style; naturalness of the background noise; etc. In order to better understand what directions need to be explored to build datasets that best support the development and evaluation of algorithms for recognition, separation or localization that can be used in real-world applications, we present here a study of existing datasets in terms of their key attributes.
TR2014-116.pdf (229.61 Ko) Télécharger le fichier
hal-01063805 , version 1 (13-09-2014)
  • HAL Id : hal-01063805 , version 1
Jonathan Le Roux, Emmanuel Vincent. A categorization of robust speech processing datasets. [Technical Report] Mitsubishi Electric Research Labs TR2014-116, 2014. ⟨hal-01063805⟩
462 Consultations
646 Téléchargements
