Two-dimensional neural field simulator with parameter interface and 3D visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
A simulator calculating two-dimensional dynamic neural fields with multiple order derivatives is presented in this work. The simulated neural fields are of the type ... where I, L and S are respectively a field's input, spatial delay kernel with axonal transmission speed c and nonlinear firing rate function S = S0 / (1 + exp(-α(V-Θ)). A Fast Fourier Transform in space is used to accelerate the integral calculation. The stochastic differential equation is useful for studying processes such as breathers, activity spread and Turing patterns shown below. The underlying code is written in Python and is therefore cross-platform. It is also open-source, allowing researchers to modify the simulator in any manner.
poster_ICNFT_Nichols.pdf (1.8 Mo) Télécharger le fichier
hal-01064205 , version 1 (15-09-2014)
  • HAL Id : hal-01064205 , version 1
Eric Nichols, Axel Hutt. Two-dimensional neural field simulator with parameter interface and 3D visualization. 3rd International Conference on Neural Field Theory, Jun 2014, Reading, United Kingdom. ⟨hal-01064205⟩
230 Consultations
62 Téléchargements
