A Survey of Classification Methods in Data Streams, Data Streams, pp.39-59, 2007. ,
DOI : 10.1007/978-0-387-47534-9_3
Data streams: models and algorithms, 2007. ,
Active learning with evolving streaming data, ECML PKDD, pp.597-612, 2011. ,
Active Learning, Synthesis Lectures on Artificial Intelligence and Machine Learning, pp.1-114, 2012. ,
DOI : 10.2200/S00429ED1V01Y201207AIM018
A stream-based semisupervised active learning approach for document classification.I n ICDAR, pp.611-615, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00855184
OASIS: Online Active Semi-Supervised Learning, AAAI, 2011. ,
Coarse sample complexity bounds for active learning.I n NIPS, pp.235-242, 2005. ,
Estimating the Support of a High-Dimensional Distribution, Neural Computation, vol.6, issue.1, pp.1443-1471, 2001. ,
DOI : 10.1214/aos/1069362732
An Empirical Bayes Approach to Detect Anomalies in Dynamic Multidimensional Arrays, Fifth IEEE International Conference on Data Mining (ICDM'05), pp.1-8, 2005. ,
DOI : 10.1109/ICDM.2005.22
Online Outlier Detection in Sensor Data Using Non- Parametric Models, VLDB, pp.187-198, 2006. ,
Cluster-based novel concept detection in data streams applied to intrusion detection in computer networks, Proceedings of the 2008 ACM symposium on Applied computing , SAC '08, pp.976-980, 2008. ,
DOI : 10.1145/1363686.1363912
Nearest-neighbor-based active learning for rare category detection, NIPS, pp.633-640, 2007. ,
D-Confidence: an active learning strategy to reduce label disclosure complexity in the presence of imbalanced class distributions, JBCS, pp.311-330, 2012. ,
DOI : 10.1007/s13173-012-0069-3
Classification and Novel Class Detection in Concept-Drifting Data Streams under Time Constraints, IEEE Transactions on Knowledge and Data Engineering, vol.23, issue.6, pp.859-874, 2011. ,
DOI : 10.1109/TKDE.2010.61
Classification and Novel Class Detection in Data Streams with Active Mining, Advances in Knowledge Discovery and Data Mining, pp.311-324, 2010. ,
DOI : 10.1007/978-3-642-13672-6_31
scikit-learn, Scikit-learn: Machine Learning in Python, Journal of Machine Learning Research, pp.2825-2830, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00650905
Can sharedneighbor distances defeat the curse of dimensionality, SSDBM, pp.482-500, 2010. ,
