New interface
Conference papers
A Spatiotemporal Data Aggregation Technique for Performance Analysis of Large-scale Execution Traces
Damien Dosimont 1 Robin Lamarche-Perrin 2, * Lucas Mello Schnorr 3 Guillaume Huard 1 Jean-Marc Vincent 4
* Corresponding author
1 MOAIS - PrograMming and scheduling design fOr Applications in Interactive Simulation
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
4 MESCAL - Middleware efficiently scalable
Abstract : Analysts commonly use execution traces collected at runtime to understand the behavior of an application running on distributed and parallel systems. These traces are inspected post mortem using various visualization techniques that, however, do not scale properly for a large number of events. This issue, mainly due to human perception limitations, is also the result of bounded screen resolutions preventing the proper drawing of many graphical objects. This paper proposes a new visualization technique overcoming such limitations by providing a concise overview of the trace behavior as the result of a spatiotemporal data aggregation process. The experimental results show that this approach can help the quick and accurate detection of anomalies in traces containing up to two hundred million events.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01065093
Contributor : Damien Dosimont Connect in order to contact the contributor
Submitted on : Wednesday, September 17, 2014 - 5:54:39 PM
Last modification on : Wednesday, July 6, 2022 - 4:17:59 AM
Long-term archiving on: : Thursday, December 18, 2014 - 11:57:01 AM
File
dlpaggreg.pdf
Identifiers
  • HAL Id : hal-01065093, version 1
Collections
Citation
Damien Dosimont, Robin Lamarche-Perrin, Lucas Mello Schnorr, Guillaume Huard, Jean-Marc Vincent. A Spatiotemporal Data Aggregation Technique for Performance Analysis of Large-scale Execution Traces. IEEE Cluster 2014, Sep 2014, Madrid, Spain. ⟨hal-01065093⟩
Share
Metrics
Record views
393
Files downloads
352
