Efficient Analysis Methodology for Huge Application Traces - Archive ouverte HAL Access content directly
Conference Papers Year : 2014
The growing complexity of computer system hard- ware and software makes their behavior analysis a challenging task. In this context, tracing appears to be a promising solution as it provides relevant information about the system execution. However, trace analysis techniques and tools lack in providing the analyst the way to perform an efficient analysis flow because of several issues. First, traces contain a huge volume of data difficult to store, load in memory and work with. Then, the analysis flow is hindered by various result formats, provided by different analysis techniques, often incompatible. Last, analysis frameworks lack an entry point to understand the traced application general behavior. Indeed, traditional visualization techniques suffer from time and space scalability issues due to screen size, and are not able to represent the full trace. In this article, we present how to do an efficient analysis by using the Shneiderman's mantra: "Overview first, zoom and filter, then details on demand". Our methodology is based on FrameSoC, a trace management infrastructure that provides solutions for trace storage, data access, and analysis flow, managing analysis results and tool. Ocelotl, a visualization tool, takes advantage of FrameSoC and shows a synthetic representa- tion of a trace by using a time aggregation. This visualization solves scalability issues and provides an entry point for the analysis by showing phases and behavior disruptions, with the objective of getting more details by focusing on the interesting trace parts.
article.pdf (514.49 Ko) Télécharger le fichier
Dates and versions
hal-01065783 , version 1 (18-09-2014)
Identifiers
  • HAL Id : hal-01065783 , version 1
Cite
Damien Dosimont, Generoso Pagano, Guillaume Huard, Vania Marangozova-Martin, Jean-Marc Vincent. Efficient Analysis Methodology for Huge Application Traces. HPCS 2014 - The 2014 International Conference on High Performance Computing & Simulation, Jul 2014, Bologna, Italy. ⟨hal-01065783⟩
349 View
220 Download
Share
