Similarity Search for Scientific Workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the VLDB Endowment (PVLDB) Année : 2014
With the increasing popularity of scientific workflows, public repositories are gaining importance as a means to share, find, and reuse such workflows. As the sizes of these repositories grow, methods to compare the scientific workflows stored in them become a necessity, for instance, to allow duplicate detection or similarity search. Scientific workflows are complex objects, and their comparison entails a number of distinct steps from comparing atomic elements to comparison of the workflows as a whole. Various studies have implemented methods for scientific workflow comparison and came up with often contradicting conclusions upon which algorithms work best. Comparing these results is cumbersome, as the original studies mixed different approaches for different steps and used different evaluation data and metrics. We contribute to the field (i) by disecting each previous approach into an explicitly defined and comparable set of subtasks, (ii) by comparing in isolation different approaches taken at each step of scientific workflow comparison, reporting on an number of unexpected findings, (iii) by investigating how these can best be combined into aggregated measures, and (iv) by making available a gold standard of over 2000 similarity ratings contributed by 15 workflow experts on a corpus of almost 1500 workflows and re-implementations of all methods we evaluated.
p1143-starlinger.pdf (835.7 Ko) Télécharger le fichier
Format : Figure, Image
hal-01066046 , version 1 (09-01-2015)
Johannes Starlinger, Bryan Brancotte, Sarah Cohen-Boulakia, Ulf Leser. Similarity Search for Scientific Workflows. Proceedings of the VLDB Endowment (PVLDB), 2014, 7 (12), pp.1143-1154. ⟨10.14778/2732977.2732988⟩. ⟨hal-01066046⟩
870 Consultations
551 Téléchargements
