Parameter estimation for a marked point process within a framework of multidimensional shape extraction from remote sensing images, Symp. Photogramm . Comput. Vis. and Image Anal. (PCV), 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00526345
The SEM algorithm: a probabilistic teacher algorithm derived from the EM algorithm for the mixture problem, Comput. Stat. Q, vol.2, issue.1, pp.73-82, 1985. ,
Stochastic geometry for image analysis, 2013. ,
DOI : 10.1002/9781118601235
URL : https://hal.archives-ouvertes.fr/hal-00793677
Estimation of the weight parameter with SAEM for marked point processes applied to object detection, Eur. Signal Process. Conf. (EUSIPCO) ,
URL : https://hal.archives-ouvertes.fr/hal-01066232
Regression shrinkage and selection via the Lasso, J. Roy. Stat. Soc. B Met, vol.58, issue.1, pp.267-288, 1996. ,
Enhancing Sparsity by Reweighted ??? 1 Minimization, Journal of Fourier Analysis and Applications, vol.7, issue.3, pp.5-6, 2008. ,
DOI : 10.1007/s00041-008-9045-x
Active set strategy for high-dimensional non-convex sparse optimization problems, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2014. ,
DOI : 10.1109/ICASSP.2014.6853851
URL : https://hal.archives-ouvertes.fr/hal-01025585
Convolutive Speech Bases and Their Application to Supervised Speech Separation, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.1, pp.1-12, 2007. ,
DOI : 10.1109/TASL.2006.876726
Convolutive nonnegative matrix factorisation with sparseness constraint, IEEE Int, 2006. ,
Statistical Analysis of Non-Lattice Data, The Statistician, vol.24, issue.3, pp.179-195, 1975. ,
DOI : 10.2307/2987782
Convergence of a stochastic approximation version of the EM algorithm, Ann. Stat, vol.27, issue.1, pp.94-128, 1999. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
A general iterative shrinkage and thresholding algorithm for non-convex regularized optimization problems, Int. Conf. Mach. Learn. (ICML), pp.37-45, 2013. ,
Algorithm 447: efficient algorithms for graph manipulation, Communications of the ACM, vol.16, issue.6, pp.372-378, 1973. ,
DOI : 10.1145/362248.362272
Sparsity and persistence: mixed norms provide simple signal models with dependent coefficients, Signal, Image and Video Process, pp.251-264, 2009. ,
DOI : 10.1007/s11760-008-0076-1
URL : https://hal.archives-ouvertes.fr/hal-00206245
