A Strategy for Parallel Implementations of Stochastic Lagrangian Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Springer Proceedings in Mathematics & Statistics Année : 2016
In this paper, we present some investigations on the parallelization of stochastic Lagrangian simulations. The challenge is the proper management of the random numbers. We review two different object-oriented strategies: to draw the random numbers on the fly within each MPI's process or to use a different random number generator for each simulated path. We show the benefits of the second technique which is implemented in the PALMTREE software developed by the Project-team Sage of Inria Rennes. The efficiency of PALMTREE is demonstrated on two classical examples.
source.pdf (283.95 Ko) Télécharger le fichier
hal-01066410 , version 1 (19-09-2014)
hal-01066410 , version 2 (30-06-2015)
hal-01066410 , version 3 (25-11-2015)
Lionel Lenôtre. A Strategy for Parallel Implementations of Stochastic Lagrangian Simulation. Springer Proceedings in Mathematics & Statistics, 2016, Monte Carlo and Quasi-Monte Carlo Methods: MCQMC, Leuven, Belgium, April 2014, 163, ⟨10.1007/978-3-319-33507-0_26⟩. ⟨hal-01066410v3⟩
611 Consultations
393 Téléchargements
