A Strategy for Parallel Implementations of Stochastic Lagrangian Simulation
In this paper, we present some investigations on the parallelization of stochastic Lagrangian simulations. The challenge is the proper management of the random numbers. We review two different object-oriented strategies: to draw the random numbers on the fly within each MPI's process or to use a different random number generator for each simulated path. We shows the benefits of the second technique which is implemented in the PALMTREE software developed by the Project-team Sage of Inria Rennes. The efficiency of PALMTREE is demonstrated on two classical examples.
Probabilités [math.PR]
