Improvement of the performance of Wind Turbine Generator using Condition Monitoring techniques, 2013 7th International Conference on Intelligent Systems and Control (ISCO), 2012. ,
DOI : 10.1109/ISCO.2013.6481205
Robust Diagnosis Algorithm for Identifying Broken Rotor Bar Faults in Induction Motors, Journal of Electrical Engineering and Technology, vol.9, issue.1, 2014. ,
DOI : 10.5370/JEET.2014.9.1.037
Electric Machines Modeling, Condition Monitoring, and Fault Diagnosis ,
On-Line Condition Monitoring and Fault Diagnosis ? A Survey, 2003. ,
Gearbox Reliability Collaborative Update, NREL U.S. Department of Energy ,
A High-Resolution Frequency Estimation Method for Three-Phase Induction Machine Fault Detection, IEEE Transactions on Industrial Electronics, vol.54, issue.4, 2007. ,
Condition monitoring & fault diagnosis system for Offshore Wind Turbines, 2012 11th International Conference on Environment and Electrical Engineering ,
DOI : 10.1109/EEEIC.2012.6221389
Wind Energy Conversion Systems Fault Diagnosis Using Wavelet Analysis Induction Machine On-Line Condition Monitoring and Fault Diagnosis ? A Survey, Proceedings published by International Journal of Computer Applications®, pp.646-652, 2008. ,
Early Fault Detection using A Novel Spectrum Enhancement Method for Motor Current Signature Analysis, 7th WSEAS Int. Conf. on Artificial Intelligence, Knowledge Engineering and Data Bases (AIKED'08), 2008. ,
Advanced Signal Processing Techniques for Fault Detection and Diagnosis in a Wind Turbine Induction Generator Drive Train: A Comparative Study, IEEE Energy Conversion Congress and Exposition, pp.États-Unis, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00532625
A Comparative Study of Time- Frequency Representations for Fault Detection in Wind Turbine, Annual Conference on IEEE Industrial Electronics Society ,
Diagnosis of Electric Induction Machines in Non-Stationary Regimes Working in Randomnly Changing Conditions, 2013. ,
Digital signal processing and modeling, 1996. ,
Spectral estimation via selective harmonic amplification, IEEE Transactions on Automatic Control, vol.46, issue.1, pp.29-42, 2001. ,
DOI : 10.1109/9.898693
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.7399
Spectral analysis based on the state covariance: the maximum entropy spectrum and linear fractional parametrization, IEEE Transactions on Automatic Control, vol.47, issue.11, pp.47-1811, 2002. ,
DOI : 10.1109/TAC.2002.804482
Probability and Measure, 1986. ,
The Retrieval of Harmonics from a Covariance Function, Geophysical Journal International, vol.33, issue.3, pp.33-347, 1973. ,
DOI : 10.1111/j.1365-246X.1973.tb03424.x
ESPRIT -Estimation of Signal Parameters via Rotational Invariance Techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing. ASSP, pp.37-984, 1989. ,
A Signal Subspace Approach to Multiple Emitter Location and Spectral Estimation, 1981. ,
Optimum Signal Processing, 2007. ,
Biosignal and Biomedical Matlab-Based Applications, 2004. ,
Digital Signal and Image Processing using Matlab, ISTE, 2006. ,
DOI : 10.1002/9781119054009
Wind turbine bearing failure detection using generator stator current homopolar component ensemble empirical mode decomposition, IECON 2012, 38th Annual Conference on IEEE Industrial Electronics Society ,
DOI : 10.1109/IECON.2012.6389263
URL : https://hal.archives-ouvertes.fr/hal-00768836
A Parametric Spectral Estimator for Faults Detection in Induction Machines, Annual Conference of the IEEE ,
On Impedance Spectroscopy Contribution to Failure Diagnosis in Wind Turbine Generators, International Journal on Energy Conversion, vol.1, issue.3, pp.147-153, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00926396
A comparative study of induction motor current signature analysis techniques for mechanical faults detection, 2005 5th IEEE International Symposium on Diagnostics for Electric Machines, Power Electronics and Drives, pp.7-9, 2005. ,
DOI : 10.1109/DEMPED.2005.4662545
MUSIC-based Diagnosis Algorithm for Identifying Broken Rotor Bar Faults in Induction Motors Using Flux Signal, Journal of Electrical Engineering and Technology, vol.8, issue.2, pp.288-294, 2013. ,
DOI : 10.5370/JEET.2013.8.2.288
Induction Machine Fault Detection Enhancement Using a Stator Current High Resolution Spectrum, Annual Conference on IEEE Industrial Electronics Society ,
Wind turbines condition monitoring and fault diagnosis using generator current amplitude demodulation, 2010 IEEE International Energy Conference, p.2010 ,
DOI : 10.1109/ENERGYCON.2010.5771697
URL : https://hal.archives-ouvertes.fr/hal-00594531
Condition monitoring methods, failure identification and analysis for Induction machines, International Journal of Circuits, Systems and Signal Processing, vol.3, issue.1, pp.10-17, 2009. ,
Parametric methods for time-frequency analysis of electric signals, 2007. ,
Advanced Signal Processing Methods for Evaluation of Harmonic Distortion Caused by DFIG Wind Generator, 16th PSCC, 2008. ,
Linear prediction approach for efficient frequency estimation of multiple real sinusoids: algorithms and analyses, IEEE Transactions on Signal Processing, vol.53, issue.7, 2005. ,
DOI : 10.1109/TSP.2005.849154
How Are We Going to Make Offshore Wind Farms More Reliable? " , SUPERGEN Wind General Assembly on, 2011. ,
Investigation of Various Wind Turbine Drive train Condition Monitoring Techniques, 2012. ,
Digital Signal Processing using MATLAB, ISTE Ltd, 2008. ,
DOI : 10.1002/9780470610992
URL : https://hal.archives-ouvertes.fr/hal-00485708
Advanced signal processing methods of harmonics and interharmonics estimation, IEE Seventh International Conference on Developments in Power System Protection, pp.9-12, 2001. ,
