A Monte Carlo Implementation of the Nonlinear Filtering Problem to Produce Ensemble Assimilations and Forecasts, Monthly Weather Review, vol.127, issue.12, pp.2741-2758, 1999. ,
DOI : 10.1175/1520-0493(1999)127<2741:AMCIOT>2.0.CO;2
Optimal estimation of changes in the mass of ice sheets, Journal of Geophysical Research: Earth Surface, vol.246, issue.4937, pp.10-1029, 2003. ,
DOI : 10.1029/2003JF000021
Initialization of ice-sheet forecasts viewed as an inverse Robin problem, Journal of Glaciology, vol.56, issue.197, pp.527-533, 2010. ,
DOI : 10.3189/002214310792447699
Determining the contribution of Antarctica to sea-level rise using data assimilation methods, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.364, issue.5388, pp.1841-1865, 2006. ,
DOI : 10.1126/science.282.5388.456
Modeling dynamic controls on ice streams: a Bayesian statistical approach, Journal of Glaciology, vol.54, issue.187, pp.705-714, 2008. ,
DOI : 10.3189/002214308786570917
Adaptive Sampling with the Ensemble Transform Kalman Filter. Part I: Theoretical Aspects, Monthly Weather Review, vol.129, issue.3, pp.420-436, 2001. ,
DOI : 10.1175/1520-0493(2001)129<0420:ASWTET>2.0.CO;2
Ensemble Kalman filtering without the intrinsic need for inflation, Nonlinear Processes in Geophysics, vol.18, issue.5, pp.735-750, 2011. ,
DOI : 10.5194/npg-18-735-2011
URL : https://hal.archives-ouvertes.fr/hal-00646682
Combining inflation-free and iterative ensemble Kalman filters for strongly nonlinear systems, Nonlinear Processes in Geophysics, vol.19, issue.3, pp.383-399, 2012. ,
DOI : 10.5194/npg-19-383-2012
URL : https://hal.archives-ouvertes.fr/hal-00714384
Shallow shelf approximation as a ???sliding law??? in a thermomechanically coupled ice sheet model, Journal of Geophysical Research, vol.45, issue.1, pp.300810-1029, 2009. ,
DOI : 10.1029/2008JF001179
Analysis Scheme in the Ensemble Kalman Filter, Monthly Weather Review, vol.126, issue.6, pp.1719-1724, 1998. ,
DOI : 10.1175/1520-0493(1998)126<1719:ASITEK>2.0.CO;2
Identification of Robin coefficients by the means of boundary measurements, Inverse Problems, vol.15, issue.6, 1425. ,
DOI : 10.1088/0266-5611/15/6/303
The physics of glaciers, 2010. ,
Creep And Recrystallization Of Polycrystalline Ice, B. Mineral, vol.102, pp.80-85, 1979. ,
Sequential data assimilation with a nonlinear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, Journal of Geophysical Research, vol.109, issue.Part 4, pp.10143-10162, 1994. ,
DOI : 10.1029/94JC00572
The Cryosphere, Bedmap2: improved ice bed, surface and thickness datasets for Antarctica, pp.375-39310, 2013. ,
Construction of correlation functions in two and three dimensions, Quarterly Journal of the Royal Meteorological Society, vol.4, issue.2, pp.723-757, 1999. ,
DOI : 10.1002/qj.49712555417
Greenland ice sheet contribution to sea-level rise from a new-generation ice-sheet model, The Cryosphere, pp.1561-157610, 1561. ,
A new 1 km digital elevation model of Antarctica derived from combined radar and laser data ? Part 2: Validation and error estimates, The Cryosphere, pp.113-123, 2009. ,
Distance-Dependent Filtering of Background Error Covariance Estimates in an Ensemble Kalman Filter, Monthly Weather Review, vol.129, issue.11, pp.2776-2790, 2001. ,
DOI : 10.1175/1520-0493(2001)129<2776:DDFOBE>2.0.CO;2
Ice-sheet mass balance and climate change, Nature, vol.6, issue.6, pp.51-5910, 1038. ,
DOI : 10.1038/nature12238
Greenland ice-sheet volume sensitivity to basal, surface and initial conditions derived from an adjoint model, Annals of Glaciology, vol.50, issue.52, pp.67-80, 2009. ,
DOI : 10.3189/172756409789624256
Notes on Basic Glaciological Computational Methods and Algorithms, Continuum Mechanics and Applications in Geophysics and the Environment, pp.222-249, 2001. ,
DOI : 10.1007/978-3-662-04439-1_13
A Sequential Ensemble Kalman Filter for Atmospheric Data Assimilation, Monthly Weather Review, vol.129, issue.1, pp.123-137, 2001. ,
DOI : 10.1175/1520-0493(2001)129<0123:ASEKFF>2.0.CO;2
Efficient data assimilation for spatiotemporal chaos: A local ensemble transform Kalman filter, Physica D: Nonlinear Phenomena, vol.230, issue.1-2, pp.112-126, 2007. ,
DOI : 10.1016/j.physd.2006.11.008
Investigating changes in basal conditions of Variegated Glacier prior to and during its 1982?1983 surge, The Cryosphere, pp.659-67210, 2011. ,
Greenland flow variability from ice-sheet-wide velocity mapping, Journal of Glaciology, vol.56, issue.197, pp.415-430, 2010. ,
DOI : 10.3189/002214310792447734
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Continental scale, high order, high spatial resolution, ice sheet modeling using the Ice Sheet System Model (ISSM), Journal of Geophysical Research: Earth Surface, vol.45, issue.B8, pp.10-1029, 2012. ,
DOI : 10.1029/2010GL043201
Anisotropic, transversely isotropic nonlinear viscosity of rock ice and rheological parameters inferred from homogenization, International Journal of Plasticity, vol.9, issue.5, pp.619-632, 1993. ,
DOI : 10.1016/0749-6419(93)90023-J
The basal stress distribution of Ice Stream E, Antarctica, inferred by control methods, Journal of Geophysical Research, vol.93, issue.C7, pp.595-603, 1992. ,
DOI : 10.1029/91JB02454
Abstract, Journal of Glaciology, vol.34, issue.131, pp.91-98, 1993. ,
DOI : 10.1029/JC094iC05p06177
Spatial patterns of basal drag inferred using control methods from a full-Stokes and simpler models for Pine Island Glacier, West Antarctica, Geophysical Research Letters, vol.36, issue.2, pp.1450210-1029, 2010. ,
DOI : 10.1029/2010GL043853
URL : https://hal.archives-ouvertes.fr/hal-00751442
A local ensemble Kalman filter for atmospheric data assimilation, Tellus A, pp.415-428, 2004. ,
Benchmark experiments for higher-order and full-Stokes ice sheet models The Cryosphere, ISMIP? HOM), vol.25194, pp.95-10810, 2008. ,
Modelling the Early Weichselian Eurasian Ice Sheets: role of ice shelves and influence of ice-dammed lakes, Clim. Past, vol.35194, pp.375-38610, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330759
A Singular Evolutive Interpolated Kalman Filter for Data Assimilation in Oceanography, 1996. ,
Stochastic Methods for Sequential Data Assimilation in Strongly Nonlinear Systems, Monthly Weather Review, vol.129, issue.5, pp.1194-1207, 2001. ,
DOI : 10.1175/1520-0493(2001)129<1194:SMFSDA>2.0.CO;2
URL : https://hal.archives-ouvertes.fr/inria-00073082
A Singular Evolutive Extended Kalman Filter for Data Assimilation in Oceanography, 1996. ,
Filtres de Kalman singuliers évolutifs pour l'assimilation de données en océanographie, C. R. Acad. Sci., Paris, Sci. terre planètes, vol.326, pp.255-260, 1998. ,
Sensitivity of a Greenland ice sheet model to atmospheric forcing fields, The Cryosphere, pp.999-101810, 2012. ,
Bayesian estimation of basal conditions on Rutford Ice Stream, West Antarctica, from surface data, Journal of Glaciology, vol.57, issue.202, pp.315-32410, 2011. ,
DOI : 10.3189/002214311796406004
Ice Flow of the Antarctic Ice Sheet, Science, vol.333, issue.6048, pp.1427-1430, 2011. ,
DOI : 10.1126/science.1208336
Modeling the evolution of Antarctic ice sheet over the last 420,000 years: Implications for altitude changes in the Vostok region, Journal of Geophysical Research: Atmospheres, vol.79, issue.47, pp.31943-31964, 2001. ,
DOI : 10.1029/2001JD900232
nonlin-processes-geophys.net/21, Nonlin. Processes Geophys, vol.569, issue.21, pp.569-582, 2014. ,
ETKF for state and parameter estimation in ice sheet modelling ,
URL : https://hal.archives-ouvertes.fr/hal-01066882
Large-scale rheology of the Ross Ice Shelf, Antarctica, computed by a control method, Annals of Glaciology, vol.24, pp.43-48, 1997. ,
DOI : 10.1017/S0260305500011915
A Reconciled Estimate of Ice-Sheet Mass Balance, Science, vol.338, issue.6111, pp.1183-1189, 2012. ,
DOI : 10.1126/science.1228102
A data-calibrated distribution of deglacial chronologies for the North American ice complex from glaciological modeling, Earth Planet An iterative inverse method to estimate basal topography and initialize ice flow models , The Cryosphere, Sc. Lett, vol.3155194, issue.7, pp.30-40, 2012. ,
Application of control methods for modelling the flow of Pine Island Glacier, West Antarctica, Annals of Glaciology, vol.36, issue.1, pp.197-204, 2003. ,
DOI : 10.3189/172756403781816338
