Grapheme To Phoneme Conversion - An Arabic Dialect Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Salima Harrat
  • Fonction : Auteur
  • PersonId : 950686
Karima Meftouh
  • Fonction : Auteur
  • PersonId : 929495
Mourad Abbas
  • Fonction : Auteur
  • PersonId : 950687
We aim to develop a speech translation system between Modern Standard Arabic and Algiers dialect. Such a system must include a Text-to-Speech module which itself must include a grapheme-phoneme converter. Algiers dialect is an Arabic dialect concerned by the most problems of Modern Standard Arabic in NLP area. Furthermore, it could be considered as an under-resourced language because it is a vernacular language for which no substantial corpus exists. In this paper we present a grapheme-to-phoneme converter for this language. We used a rule based approach and a statistical approach, we got an accuracy of 92% VS 85% despite the lack of resource for this language.
sltu.pdf (429.64 Ko) Télécharger le fichier
hal-01067022 , version 1 (22-09-2014)
  • HAL Id : hal-01067022 , version 1
Salima Harrat, Karima Meftouh, Mourad Abbas, Kamel Smaïli. Grapheme To Phoneme Conversion - An Arabic Dialect Case. Spoken Language Technologies for Under-resourced Languages, May 2014, Saint Petesbourg, Russia. ⟨hal-01067022⟩
421 Consultations
1156 Téléchargements
